3d View problem
im having this issue with my 3d view.. everything is fine while i pan and orbit the model, but once i remove my fingers from the mouse buttons the image goes like this (attachment)
any ideas?? some times its fine and others its not. i was thinking graphics card problem? but the other designer is using the exact same PC and it dosnt happen on his.. maybe a setting on mine that iv messed up??
undefined
11 REPLIES 11
Wow.....that would give me a headache.
Sorry I can't help though, I'm not on XP or AC12.
vistasp
* Do you have on-board video?
* Maybe too much RAM is being used by other apps?
* Could also be a faulty graphics card.
If you add basic machine specs in your signature, it would help.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
What are your 3D Window settings?
Certain 3D Window settings with the Internal 3D Engine can produce a picture like that.
settings are on
engine - open GL
mod - Shading
countours - best
diplay - 1300 x 840
the rest is locked out.
ill check the details and post them up.. i dont know much aboutthe PC as it just the one at work. (i didnt buy/build it. IT did)
XP pro V2002 SP2
intel core 2 duo
E6750 @ 2.66 GHz (dunno what that means?)
2.00GHz, 3.oGB of ram
ati radeon hd 2400 256 vid card
David Collins
I have the same problem, if that's any comfort for you. I think the culprit is the graphics card, an ATI Radion hd 3850 on my setup. It may be stealing RAM from OpenGL. A reboot fixes it, until the next time. It's very sporatic.
This is new in ArchiCAD 12. The same card and PC worked just fine with AC 11. It's interesting that the guy next to you with the same machine doesn't have the same problem. Are you listening to music, by any chance? Streaming audio content from the Internet seems to set it off it on my computer.
David Collins
Win10 64bit Intel i7 6700 3.40 Ghz, 32 Gb RAM, GeForce RTX 3070
AC 27.0 (4001 INT FULL)
yep thast the same here, no problem in 11, only 12.. and yeah, its very random when it happens.
i always have music playing, but its from my hard drive not streaming.
ill leave it off and see if it makes any differnace
this definitely seems to be a graphics card issue as opposed to AC.
we've had sporadic instances of this happening, in v11 and v12.
the latest, when we had a widescreen tv set as a clone monitor on a PC for a presentation and afterwards switched the TV off ( didn't unplug it from PC) but forgot to readjust graphics card settings; a couple days later, this same graphics problem started. Adjusting card settings and restart solved it.
