We value your input!
3d element gets cut off
Bling Keeta
Complex profile model beam gets cut off when moved upwards beyond a certain level. Thanks in advance for help.
Ben Ling
B.L.LING ARCHITECT INC.
Vancouver, BC, Canada
Mac Pro 3.5 GHz 6-Core Intel Xeon E5
AC 20
Bling Keeta
Further to my last post. The 3d element re-appears beyond a "vacuum"
in the middle.
Ben Ling
AC 20
You will probably find there is a slab (or another element) in a hidden layer that has a stronger building material than your beam.
So you can either delete that element if not needed, adjust the building material strengths for the beam and/or hidden element, or change the layer intersection number (in the layer settings) so the two layers have different numbers (therefore elements will not intersect).
Bling Keeta
Thanks Barry, should have thought of that.
Ben Ling
AC 20
