3d text
Is there a easy way to put text into a 3d model by using library parts or otherwise? for instance modeling a sign on a building
happy new year
8 REPLIES 8
Dennis Lee
There is a library part called exactly "3d text". I'm not exactly sure where it is now, but you can open up the library and search for text or 3d text.
ArchiCAD 25 & 24 USA
Windows 10 x64
Since ArchiCAD 9
Dwight
1: Search for "3D Text" object in Archicad Library.
2: Use a picture with object "Parapicture" attached.
Dwight Atkinson
Dennis Lee
Had some extra time to fool around w/ AC...
BTW, is there a difference between the parapicture object and the picture 10 object in the AC library? It looks like the pic seems a bit brighter in the parapicture object to me. Maybe it's good for pics w/ alpha channel..?
Windows 10 x64
Since ArchiCAD 9
how can i curve a 3d text?
Dwight
One letter at a time using the 3D Text object.
See:
http://archicad-talk.graphisoft.com/viewtopic.php?p=80313&highlight=text#80313
Here's a diagram of how it happens:
A: a series of 3D text objects rotated/multiplied standing up in a horizontal arc
B: A series of 3D text objects rotated/multiplied laying down in a horizontal arc
C: The "B" arc saved as a library object from the side i wanted to be the top.
Dwight Atkinson
Rod Jurich
Or take a peek here.
It may not do all you want but it will place 3D text at a given radius.
Rod Jurich
AC4.55 - AC14 INT (4204) |  | OBJECTiVE |
Dwight
Kewl.
You are wizard.
Thanks.
Dwight Atkinson
thanks
i decide to use the free one, because one letter at a time is a waste of time.
That's another command that now archicad should copy from vectorworks.
