9013 Hotfix for AC18? - why is it giving me this error?
rob2218
So, I go to update my AC18 to the latest hotfix 9013 and I get this message?
I have NO Cinerender app running.
GS what gives?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 REPLIES 5
Try going to the task manager and check if there is any instance of cinerender running and end process
rob2218
Did that....nothing running in background.
What gives GS?
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Graphisoft.....got any suggestions on how I can fix this?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Did you log out of Windows as suggested then log back in and re-run the update?
If you want to talk to GRAPHISOFT, why don't you call them? You are entitled to Technical Support, aren't you?
You know as well as I do that this is a User Forum, not a GRAPHISOFT Support Forum.
