2008-12-23
08:11 AM
2023-05-25
06:09 PM
Rubia Torres
2008-12-23 10:57 AM
2008-12-23 02:20 PM
2008-12-23 02:56 PM
solitaire wrote:This SEO works: wall, pipe, and slab. Slab is used to create the hole in the wall, then the slabs layer is hidden. The slab can be given a cover fill and shown in the 2D view to create the hole in the plan view.
I tried SOE, but it doesn't work and moreover, I want to denote this in the 2D floor plan too.
2008-12-23 02:59 PM
2008-12-23 08:17 PM
2008-12-23 11:37 PM
David wrote:Thanks David, I did not try SOE with a slab; just with the pipe itself (me stupid!). Great idea, I will keep this in mind now.solitaire wrote:This SEO works: wall, pipe, and slab. Slab is used to create the hole in the wall, then the slabs layer is hidden. The slab can be given a cover fill and shown in the 2D view to create the hole in the plan view.
Olivier wrote:Thanks Olivier, another great solution!
You can also use a column to make the hole. Place it on a 2D layer, hidden in 3D and Sections, with same priority as walls.
Holes will show in Floor Plan, 3D and Sections.
Djordje wrote:You are right. Despite David's and Oliver's excellent suggestions, I believe that I will go with this, as it will be closest to reality.
Why make a hole at all?
Then, who on site will make it round? No SEO in reality.
If you really want a hole, model that part of the wall with the polygonal wall and close the face of the hole with a thinner straight wall. See attached.
It will be done like that in reality. You smash a channel, lay the pipes, close it up.
You don't use SEOs for everything ... remember the first rule of CAD, now VB/BIM:
You should not just because you can.
2008-12-24 06:48 AM
solitaire wrote:Not meaning to nit-pick, Solitaire, but it's SEO -
Djordje wrote:Isn't that what Clinton (Bill, not Hillary) later said about the whole Monica-gate episode?
