AC 15 Bugs
drh64
Where do I send in bugs that I am finding in Release 15???
13 REPLIES 13
Mario Sacco
In AC 15 exporting in dwg, I tried to export label without frame; but it always insterts the frame. Pheraphs I wrong something.
MacBook M1 Max 64GB- OS X 12.2.1 - Archicad 27
https://www.archiradar.it/en/
Mario Sacco
In Ac 15 When I try to distort axis in a revolved shell, I have an error in the fill material projection. Pheraphs I wrong something, my graphic card.
A couple of things
In AC15, any existing projects brought over from AC14 lose my custom master sheets for layouts, they all revert back to vanilla AC mastersheets. Does this mean I have to reapply my custom master layouts to every existing project??
Drawing an elipse, beyond a certain size (over 50 metres) the elipse does not display properly, made up of straight edges instead of curved.
David Maudlin
I have opened many 14 files in 15, and my custom Master Layouts came in fine, I cannot think of a reason they would not be part of the file, unless the Merge command was used (which separates the Virtual Building from the Layout Book).
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
