ā2011-07-18 08:15 PM
ā2011-07-18 09:28 PM
ā2011-07-18 10:19 PM
cgrimley wrote:I was searching for it but couldn't find it.
I noticed this too. Hopefully its a setting somewhere and it didn't just go away.
ā2011-07-19 11:53 AM
ā2011-07-19 01:12 PM
laszlonagy wrote:BUT WHY????
I think the logic has changed a bit.
I don't think this is something that can be modified b a checkbox somewhere.
However, after you start stretching the Wall, just move your cursor to the endpoint you want to measure the distance from and press ALT+SHIFT. The Edit Origin will move there and the Tracker will display the values you need.
ā2011-07-19 01:27 PM
ā2011-07-19 03:31 PM
ā2011-07-19 11:23 PM
ā2011-07-21 12:45 AM
dirty wrote:I have no problem exploding a polyline into line segments -- do you happen to have Groups enabled?
Has anyone else noticed that the 'Explode into Current View' command does not seem to explode polylines into lines anymore? I used to use this command interchangeably with the 'Unify' command to change lines to polylines and vice versa. But now it seems the operations only go one direction. I can still use the magic wand to place line segments on top of an existing polyline, but must go to the added step of deleting the original.
ā2011-07-21 10:54 AM
laszlonagy wrote:Laci,
