AC 19 - curved wall bug - can't edit/move the end node
mIRage66
When editing a curved wall, the little "move node" icon is missing from the pet palette menu - once you click on the end point. It was there in the previous versions when you could normally edit the wall. It only gives me the drag option.
Searched the internet/forum, didn't find any report on this.
So unless it's only me (and that happens too often) I guess it's a bug.
Archicad 21/22/23, Windows 10 64bit,
Asus GL703VM, Intel i7 7700HQ, GTX 1060, 16GB
4 REPLIES 4
TMA_80
could this be related ?
http://archicad-talk.graphisoft.com/viewtopic.php?t=49641&start=10
AC12_27 |Win11_64bit|
mIRage66
not really, only that they are both bugs
i think that one is a section only thing - depending on which node you actually see in the view - then archicad picks it up as a node or not. both normal and curved walls get affected the same.
Is the wall part of a Group? And if it is, is grouping turned on or suspended?
mIRage66
and of course, now i try it again and it works normally
it wasn't a part of the group or a suspended group, tried it multiple times
with new walls and it didn't work.
since i needed it for a slatned curved wall, eventually i gave up and used the terrain tool. when archicad realized i don't need it anymore, it started working...
thanks for the help anyways, will try to see if i can recreate the "bug"...
