AC 21 polyline bug (adjust command)
mIRage66
Is is just me or the polylines in AC 21 do not work properly with the "adjust" command?
They will extend/adjust only if you want to make them shorter, if you want to extend them to a point further down the line they just stand there, looking, waiting, like it's none of their business.
Archicad 21/22/23, Windows 10 64bit,
Asus GL703VM, Intel i7 7700HQ, GTX 1060, 16GB
13 REPLIES 13
Eduardo Rolon
Works for me on AC21 5021
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Bruce
I should probably be more specific: the Adjust command in the menu works as expected. However, the quicker method of CTRL+CLICK to extend no longer works with polylines. Hasn't since v19. Still works for lines and arcs though.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Eduardo Rolon
This one works:
• Select Pline
• CMD+- to activate adjust
• Click on line to extend to
or
• Select Pline
• CMD+click on another line
The last one does not work for any type
AC29 US/INT -> AC08
another Moderator
Bruce
Maybe not on the Mac, but CTRL+Click (with corresponding tool active) works for lines and arcs on the PC. Used to work for Plines, but not since v20.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
