‎2019-01-25
07:03 AM
‎2023-05-25
04:53 PM
Rubia Torres
Solved! Go to Solution.
‎2019-01-28 06:13 AM
‎2019-01-25 07:42 AM
‎2019-01-25 10:12 AM
Barry wrote:Yes, i've checked every possible setting i could think of that might cause the problem, including the magic wand settings, both AC versions were using the same magic wand settings.
It is hard to say without trying it on the same DWG file.
Any chance you could attach it here?
This is be an obvious question I know, but are the magic wand settings the same in both versions?
‎2019-01-25 10:43 AM
‎2019-01-28 07:47 AM
‎2019-01-28 07:27 PM
Richard wrote:
A couple of things to try.
1) Run the lines through the line consolidation process (Edit>Reshape>Linework Consolidation), and see if you get a significant number of cleanups.
2) Use the magic wand tool settings so you don't get so many points. Try setting the distance between points to be much larger.
Also, 3) Update to the latest version (5009). May not help, but you never know.
‎2019-01-28 07:51 PM
‎2019-01-29 04:00 AM
‎2019-04-03 05:23 AM
