Got a minute? We appreciate your feedback:
Graphisoft Learn survey
AC 27 Complex Profiles - Profile Manager Crash
Romans
Hi All,
We do have problems with the Complex Profiles in AC27 (INT + GER):
When saving a modified complex profile in the profile manager, it crashes all the time Archicad.
It happens with all types of files: existing teamwork and solo projects new (empty) files from standard AC-template.
On different Apple Hardware and macOS (Intel-based, ARM, Monterey, and Sonoma).
Any experience with this?
@GS: Are you aware of this problem?
(Yes, we did send all the Bug-Reports.)
Thank you.
Kind Regards
Roman
Apple iMac Pro with macOS Sonoma, AC 5.0 to 27 INT and GER, all the latest
4 REPLIES 4
Glad you shared with all of us fellow users.  Can you here (and always in future) provide the build number of AC 27 and the build number of macOS as well.
As to the $GS - as a long time user, you do know that Graphisoft does not look to this Community for bug reports or feedback... although, hopefully, they will notice most of the important things like this at some point.  Sending in the crash reports is great... but should follow up with a report to your local technical support that references those crash numbers. 🙂
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Botonis
In case you have LAND4CAD addon installed, there was a bug with the profile manager that caused crash. Update LAND4CAD to the latest version.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
Hi Botonis,
Thank you so much for your reply!!!
Yes, we use this add-on, too, and we only installed the first edition of the plugin for AC27, not the soon-after-issued fix. There was no communication from the developer...
That is a constructive reply. This is the actual value of this forum. Dedicated users help the ones in need. Great!
 (not like the contemptuous post from the senior teacher)
Thumbs up!
Cheers
Roman
@Romans ,
I wouldn't say Karl's reply was contemptuous.
I would say it was factual.
