AC10 : Diferent Lines for Plan and Section
In reading through the "Archicad 10 Feature Comparison" ArchicadWiki site, I am puzzled as to whether the floor plan Cut line in plan can be different than the Section Cut line. If you read at the bottom of this Link, it seems to only show one line type an one pen for Cut Lines.
I believe they can be different in that the settings withing the SE Markers (Cut Elements panel) will override the element settings (which will be used in Plan).
I hope if we keep asking Graphisoft will realize that this has a benefit in certain instances. Carefully playing with the new cut plane and associated options might achieve a solution depending on your needs.
