2006-06-08 11:58 PM - last edited on 2023-05-23 05:15 PM by Rubia Torres
2006-06-27 04:40 PM
Pete wrote:This has to do with wether or not you have your roof pivot lines "on" in the onscreen view options. It should edit since the pivot line show up when a roof is selected regardless of this toggle, but it does not. Notice that you cannot snap to the pivot line in this condition as well.
Similarly, I cannot seem to select a roof and then edit the pivot line. I'll start a new thread on that (after checking for an existing one).
2006-06-27 04:46 PM
Chazz wrote:What is a schmillion button mouse? In 9 you could select an item and then option/alt click to capture the parameters and it would preferentially get the parameters from the selected item. This unfortunately does not seem to be the case in 10.
All of this points to the importance of using a schmillion button mouse and programing at least two of those buttons to address this issue: One to collect the attributes (the eyedropper tool) and the other to inject the attributes to another element (the syringe tool). This way you can, in many instances, select the element and activate its tool very quickly. Also very useful is programing a button to act as a Shift-click. this was way you can build up selection sets quickly and without touching the keyboard.
2006-06-27 05:30 PM
Mike wrote:OK, I exaggerate.... maybe an 8 or 10 button mouse.
Mike wrote:Yes, but selecting was a little-hit-or-miss. In AC 10 it works for me just fine but the methodology is definitely a little different:
2006-06-27 05:37 PM
2006-06-27 05:44 PM
Dwight wrote:Here in California -the Peoples Republic of Schwarzenegger -we call them Girly Mans.
hover and pause - seems to be too "girly" for many of our users.
2006-06-27 05:49 PM
Dwight wrote:As is true with many other things..... However, after dinking with this more it appears that you need not wait. Just get the Mercedes and drive (that is Tab) away.
a moment of patience brings success for anyone...
2006-06-27 05:55 PM
