schagemann
AC10 hotfix AUS987 installation problem
encountered the following clash between ac10 hotfix AUS987 and the roofmaker addon. it stopped the installation process halfway and generated the following error log...
(Sep 4, 2006 8:43:16 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, An error occurred and product installation failed. Look at the log file /Applications/Graphisoft/ArchiCAD 10/log.txt for details.
(Sep 4, 2006 8:43:16 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, java.lang.AssertionError: Not excected multiple matches:[/Applications/Graphisoft/ArchiCAD 10/Add-Ons/Extras/RoofMaker/Contents/MacOS/RoofMaker, /Applications/Graphisoft/ArchiCAD 10/ArchiCAD Library 10/RoofMakerAUS-MAC/RoofMaker/Contents/MacOS/RoofMaker]
STACK_TRACE: 14
at com.graphisoft.ishield.GSFileList$FileMatches.getSingleMatch(GSFileList.java:157)
at com.graphisoft.ishield.GSFileList.search(GSFileList.java:244)
at com.graphisoft.ishield.GSModuleUpdaterFiles.install(GSModuleUpdaterFiles.java:131)
at com.installshield.product.service.product.PureJavaProductServiceImpl.installProductAction(PureJavaProductServiceImpl.java:1916)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.getResultForProductAction(PureJavaProductServiceImpl.java:5195)
at com.installshield.product.service.product.InstallableObjectVisitor.visitComponent(InstallableObjectVisitor.java:369)
at com.installshield.product.service.product.InstallableObjectVisitor.visitInstallableComponents(InstallableObjectVisitor.java:333)
at com.installshield.product.service.product.InstallableObjectVisitor.visitProductBeans(InstallableObjectVisitor.java:133)
at com.installshield.product.service.product.PureJavaProductServiceImpl$InstallProduct.install(PureJavaProductServiceImpl.java:4563)
at com.installshield.product.service.product.PureJavaProductServiceImpl$Installer.execute(PureJavaProductServiceImpl.java:3758)
at com.installshield.wizard.service.AsynchronousOperation.run(AsynchronousOperation.java:41)
at java.lang.Thread.run(Thread.java:613)
(Sep 4, 2006 8:45:01 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, An error occurred and product installation failed. Look at the log file /Applications/Graphisoft/ArchiCAD 10/log.txt for details.
(Sep 4, 2006 8:45:01 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, java.lang.AssertionError: Not excected multiple matches:[/Applications/Graphisoft/ArchiCAD 10/Add-Ons/Extras/RoofMaker/Contents/MacOS/RoofMaker, /Applications/Graphisoft/ArchiCAD 10/ArchiCAD Library 10/RoofMakerAUS-MAC/RoofMaker/Contents/MacOS/RoofMaker]
STACK_TRACE: 14
(Sep 4, 2006 8:47:47 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, An error occurred and product installation failed. Look at the log file /Applications/Graphisoft/ArchiCAD 10/log.txt for details.
(Sep 4, 2006 8:47:47 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, java.lang.AssertionError: Not excected multiple matches:[/Applications/Graphisoft/ArchiCAD 10/Add-Ons/Extras/RoofMaker/Contents/MacOS/RoofMaker, /Applications/Graphisoft/ArchiCAD 10/ArchiCAD Library 10/RoofMakerAUS-MAC/RoofMaker/Contents/MacOS/RoofMaker]
STACK_TRACE: 14
(Sep 4, 2006 8:49:07 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, An error occurred and product installation failed. Look at the log file /Applications/Graphisoft/ArchiCAD 10/log.txt for details.
(Sep 4, 2006 8:49:07 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, java.lang.AssertionError: Not excected multiple matches:[/Applications/Graphisoft/ArchiCAD 10/Add-Ons/Extras/RoofMaker/Contents/MacOS/RoofMaker, /Applications/Graphisoft/ArchiCAD 10/ArchiCAD Library 10/RoofMakerAUS-MAC/RoofMaker/Contents/MacOS/RoofMaker]
STACK_TRACE: 14
(Sep 4, 2006 8:50:59 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, An error occurred and product installation failed. Look at the log file /Applications/Graphisoft/ArchiCAD 10/log.txt for details.
(Sep 4, 2006 8:50:59 AM), Install, com.graphisoft.ishield.GSModuleUpdaterFiles, err, java.lang.AssertionError: Not excected multiple matches:[/Applications/Graphisoft/ArchiCAD 10/Add-Ons/Extras/RoofMaker/Contents/MacOS/RoofMaker, /Applications/Graphisoft/ArchiCAD 10/ArchiCAD Library 10/RoofMakerAUS-MAC/RoofMaker/Contents/MacOS/RoofMaker]
STACK_TRACE: 14
only after we had moved all roofmaker associated files out of the graphisoft folder did it work.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
0 Replies 0
