AC11 Windows - interior casing?
I've been working for a long while with the AC9 Special Edition library, with few problems I couldn't work around. I'm now trying out the AC11 windows, and can't get interior casing to appear in plan, model, or elevation.
I'm not sure if its something I've done (possible to probable) without knowing it, or if it something buggy...has anyone else experienced this?
I've checked what I know: the window selection settings show that the int. casing is ON and there are real, positive values to all of the casing variables.
Thoughts?
Thanks...
John
1 REPLY 1
The setting for the jamb was greater than the thickness of the wall; rather than pushing out the casing to float in space, though, the casing just didn't appear.
