AC13 StairMaker Bug
I found a bug in AC13 StairMaker, which occurs in following sequence:
1. Make a new stair with StairMaker, set Structure to far right button /simple concrete stair, save and place on plan.
2. Select the stair, edit it and set Structure to far left button /concrete with tread/, save and view in 3D. The bottom flight is missing in 3D, only the treads are visible.
Nice!
On the positive side.
Maybe someday we will have stair tool to brag about?
Until then, rock on.
lec
I forgot to mention that the stair with treads works well if you start with it - just don't shange the type of Structure!
