AC13 : Structural Property
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2009-09-23
10:29 PM
- last edited on
2023-05-26
12:42 PM
by
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-23 11:32 PM
I've also noticed there isn't a similar setting for object based beams which may cause problems.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-23 11:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 12:28 AM
Here is a screenshot of the added panel to select load-bearing (or not) walls, columns, beams, etc.
Karl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 12:30 AM
Find & Select does not have an option to search for elements that are Load Bearing either.
Without these capabilities, I do not think it is wise (errors and omissions) to utilize this feature as you cannot audit your work...even if it does exchange to engineers somehow.
Karl
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 12:59 AM
I've also just noticed this setting
I agree that it should be selectable using the find and select tool. How else can you double-check without individually selecting every element?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 02:27 AM
I don't understand why being able to identify a wall as load bearing is supposed to be sometihng new and/or important. There have always been lots of ways to do that.
What am I missing here ? Whats useful about that? How is doing it the new way better than the old way ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 02:28 AM
Joeri wrote:Where did you get an ArchiCAD 13 demo version ? Send me a link.
I've started investigating AC13 possibilities (demo version) and I wonder why the Structural Property tab for walls, beams, columns, ... is hidden while using the AC13 template? What's the point for manually check this option in the Tool Settings Dialog Boxes?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 06:54 AM
That is somehow getting my plans to be intelligent regarding our IBC based codes. More specifically to identify when we have met the criteria or bases for, or basics of, what we call "Conventional Light Frame Construction". This allows us as designers in at least my neck of the woods,(Calif) to design (within it's defined perimeters) up to two story residences WITHOUT structural engineering.
Sure liability exists, but what else is new?
Stay within the defined code and you at least have a wrapper of protection.
A beginning?
lec
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2009-09-24 07:24 AM
