2011-09-15
07:43 AM
2023-05-25
06:02 PM
Rubia Torres
2011-09-15 04:40 PM
2011-09-15 06:05 PM
2011-09-15 10:30 PM
2011-09-16 03:10 AM
2011-09-17 03:34 AM
2011-09-17 04:55 AM
2011-09-17 07:35 AM
Nick00R wrote:It seems you've done quite a bit of work on troubleshooting this. Have you reported the problem to Graphisoft? If not you can launch the Bug Reporter directly and copy these details into the note section.
After a few more unintentional crashes I've managed to figure out that any renovation filter that has existing elements display set to 'override' will crash the file when a trace reference is turned on, without exception. I've not managed to narrow it down to any one particular attribute override, it doesn't seem to matter. Further, only when the storey selected as a trace reference has a dwg placed on the floorplan as an external drawing will the file crash.
I even started a fresh file, placed no elements except a dwg as an external drawing (not xref), selected a renovation filter that had existing elements set to display 'override' and then turned on the storey with the dwg as a trace reference and immediately crashed the file.
...any ideas?
2011-09-17 01:38 PM
2011-09-19 11:07 AM
