2016-06-28
		07:26 PM
		2023-05-23
		04:18 PM
			Rubia Torres
2016-08-09 05:11 AM
BernardoA wrote:Is this a PC problem only?
Another minor annoyance (there since AC19) is the toolbars being reset to the top right every time AC is opened. This is annoying if you use Toolbox Tools instead of palettes and have to relocate it every time you open AC.
2016-08-09 05:36 AM
2016-08-09 10:19 AM
2016-08-09 11:41 AM
2016-08-09 11:46 AM
Steve wrote:I can't get this to work at all in 3D window, actually
I am annoyed that you can't turn off a Structural Grid element using the Quick Layers Palette in the 3D window unless it is entirely in view. If you are able to select it, and it is highlighted, then you should be able to turn off the layer it is on using the Quick Layers Palette.
2016-08-09 11:50 AM
Erwin wrote:I just tried to make a little video of the behavior and it is actually working now. I tried it, it did not work right, then when I turned the video on to record it not working, it works as expected. ??Steve wrote:I can't get this to work at all in 3D window, actually
I am annoyed that you can't turn off a Structural Grid element using the Quick Layers Palette in the 3D window unless it is entirely in view. If you are able to select it, and it is highlighted, then you should be able to turn off the layer it is on using the Quick Layers Palette.![]()
Works fine in plan view, for example.
Still on ArchiCAD19 though.
2016-08-09 11:52 AM
Steve wrote:Erwin wrote:I just tried to make a little video of the behavior and it is actually working now. I tried it, it did not work right, then when I turned the video on to record it not working, it works as expected. ??Steve wrote:I can't get this to work at all in 3D window, actually
  2016-08-09 11:53 AM
2016-08-09 04:25 PM
Steve wrote:Typical
2016-08-09 05:04 PM
Erwin wrote:Pretty sure it appeared in AC19.
Well, it's never been there... I've never really used the button in previous versions, is it very handy?
