2017-07-13
02:31 AM
2023-05-24
08:29 AM
Rubia Torres
2017-07-13 02:58 AM
2017-07-13 03:02 AM
2017-07-13 08:34 AM
2017-07-13 03:22 PM
Steve wrote:
Sorry to disappoint you but the tool is not worth trying to configure yet.
They don't have even the names of the stair parts correct. Where is the Carriage? Try to configure the beams as they call them with a thrust block at the bottom and a ledger at the top. It can't even put the nosing on the nose of the tread if you edit it. It puts it on the wrong edge, or on both the front and back edge.
They need first to consult an American Carpenter to show them how a typical Stair is build, and what the names of the parts are.
Another good source is a stair manufacture to understand what needs to be shown in a good set of fabrication plans and details.
http://crownheritage.com/Products/StairBuilder
http://www.stairsupplies.com/
http://www.ljsmith.com/
http://www.fitts.com/home.aspx
http://www.creativestairparts.com/?view=mobile
http://www.stairways.org/
For some examples
These are also very good sources for drawings you can use to make custom profiles.
My personal favorite source for naming things is the "Graphic Guide to Frame Construction" details for builders and designers by Rob Thallon
its A Fine Homebuilding Book. Taunton Press Inc. 1991
ISBN 1-56158-040-6 spiral bound
Rob Thallon is from Eugene, Oregon so naturally I am accustom to the way he has written the book. Very good source if you ask me.
The new version is here:https://www.amazon.com/Graphic-Guide-Frame-Construction-Revised/dp/163186372X
2017-07-13 05:51 PM
My personal favorite source for naming things is the "Graphic Guide to Frame Construction" details for builders and designers by Rob ThallonGreat book -- I own a copy; however, we deal mainly with steel stairs, and "Stringer" is comparable to "Carriage." I'm just glad they're calling the treads "Runs" instead of "Goings" as in the Help -- of course, a little consistency would help.
2017-07-13 06:11 PM
