2017-11-1612:54 PM - last edited on 2023-05-2306:04 PM by Rubia Torres
2017-11-1612:54 PM
I've created a staircase and applied an associated railing. All great I've then associated an extension of the railing to a floor slab. All great.
However, the floor display doesn't pick up that the extended part of the railing is at the first floor and keeps showing this segment as not existing on the first floor but visible on the ground floor.
Changing the railing floor plan view to not be with associated with the stairs then makes the segments with the stair dashed.
I've tried various options but still have the same issue. Did anyone find a workaround/ solution?
