‎2018-01-28
03:44 PM
‎2023-05-23
04:12 PM
Rubia Torres
‎2018-01-29 12:24 AM
‎2018-01-29 04:33 AM
laszlonagy wrote:Thanks for help Laszlo. I did check to see if there were duplicate objects and there is only one. I am trying to add attachments, but they are not loading. I've saved them as jpeg & pdfs to try different formats and they are small sized too... arrrg!
Could you attach a screenshot or two to illustrate the problem?
Could there be two instances of the same Stair element at the exact same location?
‎2018-01-29 04:49 AM
TDabney wrote:Change your background colour to test your theory - you can always change it back.
It's as if I have chosen to show them in the section/elevation windows using a white pen (I work w/a white background). The object is there, I can select it as normal, but if not selected, it's not visible...
‎2018-01-29 05:16 AM
‎2018-01-29 06:25 PM
Barry wrote:Hi Barry,
‎2018-01-29 07:11 PM
‎2018-01-29 07:12 PM
‎2018-01-29 07:13 PM
‎2018-01-29 07:14 PM
