AC21 stair boundary bug
julienK
I'm trying to make a circular stair in a square staircase.
When creating a stair with the arc center point method, when editing the boundary and making the boundary segment straight they will revert to arc everytime I change a parameter in the stair tool.
I made a video to show what I mean: https://youtu.be/Adb-1l8LhKk
Is there a way to lock the stair boundaries ? can I fix this or is it a bug ?
This only happens when creating the stair with the arc centerpoint method, when using another method the boundaries remain unchanged when editing the parameters.
Thanks for the help.
4 REPLIES 4
julienK
Anyone got a solution for this or know I can report this bug to graphisoft ?
Thanks
You should be able to report bugs to your local distributor.
I have verified that it is a bug in my ARCHICAD 21 and reported it to GRAPHISOFT last week.
julienK
Two archicad 21 updates have gone by and this bug is still there.
I just read the update 6000 changeling and still no mention of this being fixed.
I reported this bug to my distributor as suggested here but still nothing?
Can someone tell me if this is still in the pipeline to be fixed or when we might see a fix for this?
Thanks
