Curved morph display issues
After restarting Archicad curved morph started displaying in 3D window this kind of way. Everything is fine on the floor plans but not in 3D. Any idea how to fix this?
2 REPLIES 2
Daniel Kovacs
Graphisoft Alumni
Graphisoft Alumni
Hello Solo Hal,
By this single picture, it is hard to tell. I have nothing for scale, but I would guess that it is a really small element with tiny curves, since the curves seem intact, only the edges are misplaced, so it might be just the segmentation.
You can try the 'Design>Modify Morph>Modify Segmentation' to double the segments in a curve, that might fix it. If not, then I would need the file to see what the problem might be. You can send it over to me in a Private Message if you want.
Regards,
Daniel Alexander Kovacs
GRAPHISOFT
Hello dkovacs,
thanks for replying!! It's actually quite big element. It's a 1000mm wide road. I did try to fix this by doubling segments but nothing helped, so I just gave up on morph and remodeled everything with slab. I'm just curious what could have gone wrong? Thank you anyway!
Cheers
