2022-08-26 02:46 PM
I'm getting some serious crashes after I go to the publisher sets and navigate through it:
Steps that makes a file to crash:
After pressing "repair" I get this:
And my project file comes corrupted, which means I've no longer able to open backup files. After a lot of time to restore all steps in the project before this error I'm still unable to use publisher because of the AC crashes everytime I do these 2 steps.
I'm writing and hoping that Graphisoft will fix this as soon as possible.
2022-08-26 05:08 PM
Is it just that one file or does it happen to all files?
If just that file, have you tried the 'Open & Repair' option on the file yourself?
If that does not work, have you sent the file to your local support for them to look at?
2022-08-29 08:34 AM
@Barry Kelly ,
'Open & Repair' has worked just fine.
Apparently, something was bad with my file.
But, these two
is still a mystery for me.
Anyways, thank you!
2022-08-29 09:44 AM
I have never come across that 'Project Data Error' message (touch wood!).
The 'cannot create temporary documents' could be a user permission problem depending on where it is trying to save the files, or maybe a full hard drive?
But that is just a bit of a guess.
2023-01-25 12:10 PM
Also having similar with Teamwork file that crashes.
How it happens:
1. In "Publisher Set" Creating new folder with layouts to be published;
2. Making SEND/RECIEVE, Release ALL;
3. Closing Teamwork project;
4. When trying to open teamwork project again ArchiCAD crashes. No one can open project in Teamwork.
If I download *.pln from BIMcloud and try to open it crashes. Open and Repairs fixes file for that period of time, but If I add new folders or elements in Publisher Set same crash occurs.
2023-02-07 12:49 PM
Looks like we found what is crashing AC26 with all files. When you change publisher elements to DWG and tick "Merge to one DWG file" and press save or SEND/RECIEVE in teamwork file case, file is damaged and cannot be opened. Video replicating crash in link below: https://www.youtube.com/watch?v=dSIRcYUbQ7o
@Barry Kelly this is not solved issue in AC26, maybe you can adjust this tread to be not solved ?
