a month ago
Hi, how can i move the hotspot of the residual connection in a WC?
Operating system used: Mac Intel-based Tahoe 26.4
a month ago
Hi @Guillermo1
Both connections have their magenta hotspot at the same position in the plan view, so you can move the water connection and the waste water one independently. Anyway you can also change the exact connection length for any of the systems in the Settings Dialog (Ctrl+T).
(Check the attached video)
a month ago
Im refered to this , in the floor plan,
a month ago - last edited a month ago
Hi @Guillermo1
The easiest way is to draw a guide or a temporary line as a reference and move the magenta hotspot.
a month ago
as object it works, but when it converted to equipment lost the hospot mobility, i guest gonna let it as an object
