2005-01-13 02:26 PM - last edited on 2023-05-23 05:23 PM by Rubia Torres
2005-01-13 05:26 PM
Rod wrote:As you said yourself, this is probably the box problem. Try the same library on a faster box, and see.
Since upgrading from 8.1 I have been frustrated by the apparent slowness when switching views in the preview box in the door, window or object tools, as well as when revising scripts in library parts.
2005-01-14 12:13 AM
Rod wrote:Hi Rod.
Generation of elevation/section appears no faster than 8.1. This I fear is only going to be fixed by a "faster box".
If this is so, then ok, need to budget for a G5.
Has anyone else using similar hardware noticed anything?
Appreciate any response, thanks.
