AC9 Trouble with shift key selection
If I try to select several items with shift key, than it doesn't work (this funcktion needs sudenly very much power...)
Can somebody help me?
Ben Odonnell
Jakop,
Could you please be a little more specific? What were the element that you are trying to select? etc etc.
Thanks mate.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobjectĀ®
Get your BIM objects from bimobject.com
In Windows: try turning off CAPS LOCK on your keyboard.
This is a good way of going insane until you discover the trick...
I have now solution.
The trouble is because of CPU.
After reinstallation CPU is too much loaded, so that no power more !!
I switched off several starting programm, after this action it goes.
Now I know, to select many objects with shift-key needs many CPU power.
