Crash in PlotMaker 9
Recently I have a big problem w/ PlotMaker 9. Every time I worked on plot maker layout window, when I dragged drawing just a few times, it crashed. I don't know why this happened.
Please help me figure out this problem.
Thanks.
4 REPLIES 4
Signature? configuration?
Unfortunately I have the same problem since the Plotmaker 9.0
If somebody has the solution, I'm interested too
Thanks,
Best regards, Ede
Ben Odonnell
Thanks.
Mark one of the offending views and try changing it to "B&W Bitmap preview"
Drag your views around like you described and see if Plotmaker still crashes.
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
Djordje
Config? OS?
You sent the Bug reports duly filled, right?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
