2015-05-14 02:38 PM
2015-05-20 10:12 PM
stefan wrote:I was referring to rendering with ArchiCAD.Steve wrote:What do you mean? The 3D Window display is fully using the GPU (OpenGL Acceleration). Or do you mean doing more general calculations on the GPU, such as preprocessing data or simulations such as EcoDesigner?johnadrian wrote:Still no GPU with ArchiCAD.
"Beta testers have told me that it’s a significant improvement and absolutely screams on Apple’s new Mac Pro, which comes with an Intel Xeon processor with up to 12 cores." ". . . ArchiCAD 19 is the only multi core BIM tool that could justify the purchase of a lovely Mac Pro and make use of the cores on its Xeon processor."Thank you for sharing the article it is a good read
With a full multi-thread approach which seems to have received a huge boost in AC19, ArchiCAD seems quite capable and suitable for current generation of hardware.
But the GPU is being used extensively when using ArchiCAD. If you doubt it, just turn off hardware acceleration in the settings. And then try to look at textures and shadows in real-time.
2015-05-21 01:07 AM
Steve wrote:stefan wrote:I was referring to rendering with ArchiCAD.Steve wrote:What do you mean? The 3D Window display is fully using the GPU (OpenGL Acceleration). Or do you mean doing more general calculations on the GPU, such as preprocessing data or simulations such as EcoDesigner?
My mobile workstation came with a general purpose video card and a
2GB nVIDIA Quadro 4000M for use with processing files that are compatible with GPU processing. I use it with Maxwell Render but ArchiCAD rendering is not taking advantage of it because ArchiCAD is not GPU compatible in that regard. ( as far as I know )
Same with ArtLantis 6 rendering. It does a few things associated with getting the rendering set up using GPU but the rendering engine is not GPU compatible. Neither is CineRender as far as I know.
I am relatively ignorant about Open GL, Open CL, GPU, CPU, etc..
What I would really like to know is what the limits are with ArchiCAD as it relates to rendering/graphics computations... so I know how to invest in a graphics card for my next Workstation.
I am considering the Quadro M6000
http://blogs.nvidia.com/blog/2015/04/09/quadro-m6000/
My strategy for buying computers has been to pick the best graphics card I can afford, and then see what computer I can buy or lease that has that card. If the computer will support the card I want, it will do everything else I need as well. This has in the past always led me directly to the Dell Precision Workstations. I am out growing my little M6600 which I replaced my desktop workstation with some years ago. I think I will go back to a desktop workstation because you get so much more bang for your buck compared to the Mobile Workstations.
I will still be getting the best graphics card I can afford because I am using Maxwell Render which has no real hardware limits, but I will still need to know what cards are beyond the limits of what would be useful for working with CineRender.
How would ArchiCAD/CineRender run on an nNIDIA GRID vGPU ? http://www.nvidia.com/object/virtual-gpus.html
2015-05-21 04:22 AM
2015-05-21 05:04 AM
Steve wrote:
I have Maxwell v3.1 http://www.maxwellrender.com/
I can render with GPU (CUDA cores) nVIDIA Quadro
Why would I want Octane? Perhaps I should switch?
2015-05-21 05:25 AM
2015-05-21 05:55 AM
Steve wrote:
Maxwell has been working inside of ArchiCAD for several years now.
There is an ArchiCAD plug-in for Maxwell. And you can use Maxwell Material in ArchiCAD.
2015-05-21 08:42 AM
2015-05-21 09:06 AM
Steve wrote:
Not really. The Maxwell add-on does two things. CPU processing has many advantages for certain kinds of things done in ArchiCAD. The GPU functions are not taking place in ArchiCAD, they are taking place when the ArchiCAD model is exported to Maxwell render which is then using the GPU functions of my nVIDIA Quadro graphics card. The CPU processing with Open GL is being done with the other video adapter. The Dell Mobile Workstations have two video adapters. The idea is to get the best of both CPU processing for the things that are done best that way and also the ability to use GPU processing for rendering with programs can handle it.
This is just my rather ignorant understanding of it.
2015-05-21 10:12 AM
2015-05-21 11:33 AM
Bricklyne wrote:We use OpenGL also in 2D windows (on Mac, PC I think uses DirectX), so things like panning, input, trace/reference etc can utilise OpenGL to provide feedback. We have also made improvements to speed these up in AC19, as well as with the 3D navigation as already mentioned.
ArchiCAD uses your GPU for the 3D Window functions when modeling and working in 3D.
That's what the OpenGL implementation entails.
(conversely, your 2D window functions - Sections, elevations, plans etc - leverage the CPU and more pointedly the multicore capability of multicore CPU's (which pretty much all computers are these days))
