2015-10-26 05:16 PM
2015-11-12 01:11 AM
2015-11-12 01:43 AM
2015-11-12 03:12 AM
2015-11-12 05:45 AM
2015-11-12 07:55 AM
2015-11-12 01:25 PM
stefan wrote:I had the same problem but solved it: In the finder, 'get info' on the folder of Archcad 19, then do a 'apply on included elements ' by clickin on the wheel at the bottom of the dialog box. (in dutch: 'pas toe op ingesloten onderdelen'. So it's a permissions problem.
I get an error: "ArchiCAD 19 Update (4011) cannot access one or more files/folders in Macintosh HD:Applications:GRAPHISOFT:ArchiCAD 19 INT"
I have more than one install (NED + INT) in different folders. Last time I had this error, I removed ArchiCAD and reinstalled completely. Not the most pleasant waste of time...
And with the other installation, I get the following warning:
"Some separately installed add-ons have been found which have lower version numbers than this Update and ArchiCAD 19 (build 4011), found at location ..."
Any hints? I was under the impression that a Hotfix only pertained to the underlying ArchiCAD itself? Add-ons are not included and there are usually no updates available.
I'm talking about the Rhino-connection and the MEP module. The others are the ones we compiled ourselves from the DevKit.
2015-11-13 01:02 AM
rc3d wrote:At this time major issues in ARCHICAD 19 and 18, which are specific to Windows 10 and OS X 10.11 El Capitan, are resolved by applying recent updates from GRAPHISOFT. Version 19 and 18 users who have installed the updates may upgrade to Windows 10 or OS X 10.11 El Capitan and potentially expect only minor issues, if any at all, specific to this OS version. For full details see the following articles:
What would Graphisoft recommend as a fix to the Door/Window dialogue box crash as a result of the Microsoft Update (KB3097877). Uninstall the Update or Upgrade to Windows 10? I have been holding off Upgrading to Windows 10 until all known Windows 10/ArchiCAD 19 conflicts had been resolved. Are there still any known conflicts?
2015-11-13 09:06 PM
ron wrote:Today i update the os x and check archicad 17. The basic function are ok. For the drop-down menus issue , i add the panel (show on stories) from work environment profiles .
does anyone know if Archicad 17 is affected by El Capitan
2016-03-19 11:08 AM
NCornia wrote:The latest updates for 18 and 19 have apparently fixed the open-save dialog box problem as well as the shadows under windows effect. However, the Help Center article on Windows 10 still lists them as known issues. What gives? As July approaches and more people consider moving to Win10, it can cause some serious confusion.
2016-03-21 01:28 PM
