Hi Csaba,
Please don't change things mid-flight in a version for what is probably one of the last hotfixes for version 20.
Maybe change it as a 'new feature' for 21 but I would rather that didn't happen there either.
Fortunately for me it looks as if my template is set to use 'Uncut, contours, so I should see no change.
I don't particularly like using that as it forces lines to all boundaries, but I think it is because we had problems with it many years ago, or maybe it is because this option never existed in the early days and it is the default that just crept in.
I can't really remember now.
I know we have had trouble with the cut surface of the slab disappearing a few versions ago that got fixed.
If we really donāt want a line on the boundary then we will go over it with a white line.
However I feel (and I am sure Ben will as well) that when the edge of an element is on the limit of the section/elevation then that should still be there when 'no contours' is chosen.
It is a fine line (pardon the pun) but the element is still being cut and so should still be seen.
Otherwise we will have to set our sections to a limit of -1mm (or similar) to trick the slab into showing (or manually add lines).
This should not be necessary.
If we don't want the slab to show we could easily turn the layer off in that view or increase the limit of the section by a small amount.
Maybe there should just be 2 states, āno contour overrideā and ācontour overrideā.
āNo contour overrideā will show what you have ā if an element is in section and even if it is just the surface on the section limit it will show. If an element is not in section and extends beyond the limits of the section there should be no edge contour (no cut).
This is how the āno contoursā should work in my opinion (as it was before).
āNo contoursā is probably a bad name which is why I think it should possibly be āno contour overrideā
āContour overrideā will then allow the contours to be set as any line type required (although it would be better to be able to override all 4 edges independently).
It could also have an option for āno lineā which would give the effect that you have now changed the āno contoursā option to.
