2018-05-02 06:24 PM
2018-05-09 08:04 AM
2018-05-09 08:28 AM
Steve wrote:I think the answer is that the Working Units Dialog has been extended and includes new fields for Area and Volume. There are now settings for Length, Area, Volume and Angle, which correspond to the 4 new Data Types available for Properties. These control the format and decimals values are displayed for these data types in the Property Manager Dialog.
I have been asking the question about how Expressions may be limited by the Calculation Units available for Interactive Schedules since last February. 150 views on the BETA Forum 0 replies.
2018-05-09 09:24 AM
LaszloNagy wrote:As far as I can tell the property manager uses the units set in the 'Calculation Units'.
Which means that if I understand you question right, then Calculation Units settings have no connection to anything you do in the Property Manager Dialog, as far as I know.
2018-05-09 10:13 AM
2018-05-09 07:42 PM
Barry wrote:I think that works for me! I will check it out.
Steve,
I have replied to your post in the Beta forum rather than going a bit off topic here.
We can start a new post if people are interested and don't have Beta access - but it would probably be better to wait till 22 is released.
For those possibly still interested...
It is easy to calculate board feet (I now know it it the volume of the timber divided by 144 cubic inches).
You just can't show the unit in the total of a schedule - because we can't edit that.
Best we can do is add it to the title.
2018-05-10 03:55 AM
poco2013 wrote:? The Board Foot is a Volume. 1 Cubic Foot = 12 Board Feet.Barry wrote:Boards are rounded up to standard lengths of 2' increments with a limit of 20' (16' practically) of which there is no function presently defined. You would have to use the IF Function to set a constant then use that constant in another formula to cal Bd Ft. (There is no SET variable function ). Also the if function always returns a value which make the logic near impossible. You then have the problem of which calculation is done first as there is no way to control the sequence of calculations unless possibly it is done in the order listed in the property manager -- and this approach may create conflicts with other formula?
I am not familiar with the term 'board feet' but you can certainly determine the length of an element and round it up to ordering lengths.
I'm guessing most would find this procedure as too confusing?
2018-05-10 08:52 PM
2018-05-11 09:56 AM
2018-05-11 10:19 AM
2018-05-20 11:20 PM
