ARCHICAD STARTUP WINDOW
I dont know why, but whenever I open a new instance of archicad i would open a new project.. instead of appearing the usual startup window where i can select to open an existing project..
where can i activate it again?
5 REPLIES 5
Quikin ,
A good mystery. According to Archicad Help, if you have disabled the start up dialog then:
To enable the start up dialog box again, use the File > New & Reset All command.
However when I tried this, there is no Reset All command in AC-13, maybe a bug, maybe a senior user knows of a workaround.
Snap
PS Of course, you can always reinstall AC...
Eduardo Rolon
Press Opt/Alt while in the menu, it should show up.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
ohh nice.. thnx
Eduardo Rolon
por nada.
AC28 US/INT -> AC08
another Moderator
don't forget Options/Work Environment/Enable all informational messages
