2024-04-10
03:13 PM
- last edited on
2024-04-16
10:43 PM
by
hi all im new to archicad and have an assignment due soon and have somehow closed where I would access things like walls, objects, stairs etc im on mac can anyone plz help me out @eer in the attached image on the left hand side of the photo there used to be a tab bar where I could select the walls etc now its gone and i cant get it back and apoglies if I have posted this in the wrong place im stressing right now lol
Solved! Go to Solution.
2024-04-10 06:23 PM
Hi @harryparso ,
You can bring back the Toolbox through the "Window" menu:
Best of luck with your assignments and learning journey!
Community Expert | GRAPHISOFT SE
Did you get a helpful answer on the forum?
Give it back to the Community by marking it as an accepted solution!
2024-04-10 04:13 PM
That's part of your work environment. You can go to Options>Work Environment>Apply Profile to get back the one you were using. Alternatively, you should be able to access the palette via the Window>Palettes>Toolbox.
2024-04-10 04:13 PM
2024-04-10 06:23 PM
Hi @harryparso ,
2024-04-12 01:20 AM
thank you so much saved my life @Rubia Torres
