Active linking partial model to another AC file
keene kopper
I'd like to know if its possible to have part of another AC model linked into another totally separate AC file? I'd like to be able to have two instances open of AC with two separate files open, one master file and another with a model that's linked into the master, and when edited, is reflected in the master file. Is this possible?
TV / Film Production: Sr. Set Designer
Art Directors Guild, Local 800
Archicad Latest Version
MacBook Pro (15-inch, 2018), 2.9 GHz Intel Core i9, >32 GB 2400 MHz DDR4, Radeon Pro Vega 20 4080 MB, Intel UHD Graphics 630 1536 MB
It is possible, this is what Hotlinked Modules are for.
When the source file of the Hotlinked Module placed into the Master file is modified, you will need to update it manually in the Master file, it will not update automatically.
7 REPLIES 7
keene kopper
@LaszloNagy
For some reason the option to place hotlink is not an option, see screen shot. The second screen shot is directions to place a Hotlink Module...
Go to the Work Environment Dialog and add these missing commands to the File menu.
Maybe you have imported your Work Environment from a previous version and this is the4 reason why these commands are currently not in your File menu.
keene kopper
For some reason, its not even showing in the Work Environment settings. See screenshot.
Lingwisyer
Guru
If you are using ArchiCAD Solo, hotlinks are not available.
Ling.
If you are using the full version, then in your screen shot you are listing "All menus in alphabetical order".
Because the commands are not in your menus you will not see them.
Try listing "All commands in alphabetical order".
keene kopper
I'm using solo, unfortunately. Thanks for the responses!
