ā2004-12-28
08:01 PM
ā2023-05-26
03:18 PM
Rubia Torres
ā2004-12-28 08:23 PM
ā2004-12-28 08:46 PM
StuartJames wrote:Thanks Stuart, I appreciate the cautions.
(note that many scanners elongate images by up to 2% so the X-scale may be different to the Y-scale, hence the two reference lines)
HTH - Stuart
ā2004-12-29 01:53 AM
ā2004-12-29 03:11 AM
Dwight wrote:Thanks Dwight.
most programs assume 72 dpi as being 100% and that is way off considering most LCD panels are 100dpi [ie: for actual size make it 141%]
importing scans into ArchiCAD is tricky - most reliably use the figure import tool rather than just pasting it in.....
ā2004-12-29 08:07 AM
Regarding the importing of raster images....I'd still like to find the answer as it creates a lot of extra work.
ā2004-12-29 02:00 PM
MSotero wrote:The other guys have commented on 'Actual Size'. As for 'correct world size' a _lot_ of investigation has suggested the following 'guidelines' for use in our office;
... maybe my scanner is pretty accurate because I can lay my sketches over my plots and they always match (if I rescaled them when needed per my original post).
ā2005-01-03 07:21 PM
MSotero wrote:You probably already know how to do this.
...is there a way to make actual size do what it says, actually be actual size?
ā2005-01-03 07:50 PM
ā2005-01-03 11:47 PM
Dwight wrote:"Far better"? "Fewer steps"? I am sceptical. I can't.
Using stretch has problems since figure images aren't perfectly displayed at all screen zooms. The other problem is accuracy since stretching to hit non-hotspot locations [within the figure, for instance] isn't accurate. This will show up when you zoom in closer than the zoom where you actually stretched the element.
Far better to establish the actual size of the rectangular figure and assert it in the figure dialog box. And fewer steps, too.
