jakubc7
Additional Reference Levels
Is there a way to add more reference levels in:
Options > Project Preferences > Reference Levels ...
2 custom levels is a bit limited ... split level houses and commercial projects could definitely use more. Wishlist or is there a way already?
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
2 Replies 2
GeorgieB82
jakubc7 did you find an answer to this?
AC25 UK Solo
Windows 10 Pro, Intel Core i7-4790, 16GB RAM, NVIDIA Quadro K600
jakubc7
No GeorgieB82, I don't believe anything has been done to allow additional levels although I imagine it would be an easy thing to add?
Keep in mind that you can change the reference levels without having any effect on the model. That way you can keep changing them to suit whatever you need to reference to at given time.
If you use "Sea Level" instead of Project Zero as your datum (as many people do ... and it does have its advantages), you technically gain a Reference Level slot.
