2011-01-27 02:11 PM
2011-01-28 04:10 AM
2011-01-28 05:37 AM
2011-01-28 04:00 PM
Peter wrote:The problem is you would have to lose the click to deselect which I use constantly. This is actually one of my main irritations with AutoCAD, the chore of deselecting stuff. Perhaps there is a better way (besides the context menu) that I don't know of.
...But it would be interesting to try out ArchiCAD using an additive selection method; it might work even better!
2011-01-28 04:18 PM
The problem is you would have to lose the click to deselect which I use constantly. This is actually one of my main irritations with AutoCAD, the chore of deselecting stuff. Perhaps there is a better way (besides the context menu) that I don't know of....
2011-02-01 05:03 AM
2011-02-01 07:09 AM
2011-02-01 10:07 AM
Barry wrote:Right now shift is a toggle between selected and unselected states. What Darius is suggesting is to use the alt/option key for deselection. The problem I see with this is that alt/option by itself or in combination with other keys already has other (valuable) functions.
Personally I can't see the difference between using the SHIFT key to deselect elements or the ALT key to do the same.
2011-02-01 02:53 PM
Matthew wrote:Choices, gentlemen! The idea is to make it an option, not a default state. I guess lot of you felt uncomfortable at first with the change from 8.1 to 9 (at least it was for me) yet with time one understands the power of added choices.
I find that ArchiCAD has the most elegant, subtle and complex modifier key to cursor/click relationship of any program I have used and I doubt at this point that any change is likely to do more harm than good.
2011-02-01 10:19 PM
Darius_bd wrote:I have seen good programs crushed by the addition of too many choices. Adding features is not always a good thing
Also, Im not saying it has to be with Alt. Maybe Shift+Alt. The point is that intersection-selection is not the best way of selection.Alt/option+click and shift+alt/option are already dedicated to important functions, as are command/control+click and command/control+option/alt+click. There really isn't much room for other functions here.
Just yesterday I draw a square to select some elements in an axis I needed to move but I left 3 lines of a square unselected. If I had additive selection, I would just needed to draw a "Entire Elements" square selection over the square with shift and done. With intersection-selection, I do that, and I end up with those 3 lines selected but the first line unselected. Yes, it could be as easy as go clicking every line while pressing Tab to keep the right one selected, but compare that many clicks and concentration to just drawing another square.The condition you describe is a rare one in my experience and easily avoided most of the time. When I do run into this it doesn't seem to hard to click to deselect and then click, click again for the correct selection.
And that's just 3 lines of a square, sometimes I need more complex selections that just makes me deselect everything and start again.
Imo, there should be an option (as I guess by now this behaviour cant be changed in archicad) for the kind of selection that happens when one presses shift (additive or intersective) and to define another combo, when additive is selected, to deselect.Revit has this feature (control to select, shift to deselect) and I find it more annoying than helpful, and that's just by itself and not counting that Revit largely lacks ArchiCAD's smooth and sophisticated selection tools.
