2010-02-09
11:46 AM
- last edited on
2023-05-26
03:23 PM
by
Rubia Torres
2010-02-09 12:33 PM
creative wrote:Hi,
How do I add plaster thickness to walls already created?
2010-02-09 04:06 PM
2010-02-09 05:19 PM
creative wrote:I'm not sure I fully understood what you meant by that. If you are referring to changing the thickness of each skin, then try duplicating the composite structure and see if the new one can be edited.
i am not able to select the EDIT SELECTED ITEMS in the composite structure
2010-02-10 07:45 AM
2010-02-10 08:10 AM
creative wrote:That is strange... It's true that when I close both tabs ("Edit Skin and Line Structure" and "Edit Selected Items"), it shows like in your image ("Edit Selected Items" is greyed and cannot be modified). But when I click on "Edit Skin and Line Structure", it becomes active and it behaves normal. Also make sure you have one skin or line selected (although this happens by default).
when i click on edit selected items it slide down and closed and is greyed(fig)
2010-02-10 08:41 AM
adytc wrote:I tried selecting 1 skin or line but the problem persist.creative wrote:That is strange... It's true that when I close both tabs ("Edit Skin and Line Structure" and "Edit Selected Items"), it shows like in your image ("Edit Selected Items" is greyed and cannot be modified). But when I click on "Edit Skin and Line Structure", it becomes active and it behaves normal. Also make sure you have one skin or line selected (although this happens by default).
Hope that helps,
Adrian Tudoreanu
2010-02-10 09:45 AM
creative wrote:I don't think so (or at least nothing in the work environment that could be related to this issue comes into my mind). One last thing ... try opening a new (blank) project, using the default template and see if the problem persists.
Do i need to change any settings in work environment?
2010-02-11 08:42 AM
2010-03-05 08:15 AM
