‎2009-04-17 02:39 AM
‎2009-04-17 03:50 AM
A quick way to move elements on the screen is to use the Nudge feature: select one or more elements, then use Shift + arrow key (Left/Right/Up/Down) to move the element left, right, up or down. The Nudge factor - the increment by which you will move the element - is the same as the distance entered for your Snap Grid in View > Grid Options > Grids & Background. To Nudge a selected element in larger increments, use Shift + Alt + an arrow key. This will move the selected elements by the distance entered for your Construction Grid in View > Grid Options > Grids & Background.
‎2010-01-07 06:44 PM
‎2010-01-08 05:55 PM
