Adjust Nudge Increments?
matthewjj
Does anyone know if there is a way to adjust the distance the Nudge command uses? I am trying to use it in the Sheet environment and the smaller nudge still move things like an inch at a time.
matt johnson
archicad since 2004
imac 27, 4.2 GHz Intel i7, 16 GB RAM, radeon 575 4 GB, macOS 10.14.6
imac, 4.0ghz i7, 16gb ram, Radeon M9 390 2GB, OS X El Capitan
vistasp
Hi Matt,
Quoting from the AC12 New Features List PDF:
A quick way to move elements on the screen is to use the Nudge feature: select one or more elements, then use Shift + arrow key (Left/Right/Up/Down) to move the element left, right, up or down.
The Nudge factor - the increment by which you will move the element - is the same as the distance entered for your Snap Grid in View > Grid Options > Grids & Background.
To Nudge a selected element in larger increments, use Shift + Alt +
an arrow key. This will move the selected elements by the distance
entered for your Construction Grid in View > Grid Options > Grids & Background.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
matthewjj
Beautiful! Thanks vistasp! I have been pining for this feature for years in Archicad and was bummed out that I couldn't adjust the nudge setting. One would think a new feature would have a little better documentation in the help menu. Thank goodness for Archicad-Talk.
Also, uploading an image with the nudge settings highlighted.
matt johnson
archicad since 2004
The following places discuss the Nudge feature in ArchiCAD Help:
ArchiCAD 12 New Features List : Nudge/Align/Distribute Elements
Interaction : Techniques : Moving Elements : Nudging Elements
User Interface Reference : Dialog Boxes : Grids & Background Dialog Box
