Adjusting brick size
I have a client who wants the brick to be shown as 4x12 size.
Is there any way I can modify skins, building material or anything at all to change the way the brick shows on everything from rendering, to 2d and 3d??
also, anyone suggest a good therapist?
1 Reply 1
So I have been using brick on my last two projects and I have some tips for you.
- First you need to make a Fill 4x12 duplicate the runing bond fill and change dimensions.
- Duplicate the brick texture and change the texture size in Open GL and Cinerender
- Apply new 4x12 vectorial fill
If you use complex profiles here is a thread that will help you figure out if you want to go that route. http://archicad-talk.graphisoft.com/viewtopic.php?t=44632&highlight=
