ā2009-07-17 05:05 PM
ā2009-07-18 12:37 AM
ā2009-07-18 12:45 AM
ā2009-07-18 12:59 AM
ā2009-07-18 01:32 AM
ā2009-07-20 07:47 AM
Sloan wrote:I think it has 4 straight sides (Planes), you can model it with walls and then save it as a rotated GDL object.
What do you think would be the best way to model the first image? Is there any less time consuming way that just making tons of different columns?
ā2009-07-20 01:30 PM
ā2009-07-20 05:26 PM
Sloan wrote:You can make holes perpendicular to the curved roof.Steve wrote:BIG, on of my favorite firms...
this one is kind of cool too.
On this one, I think I can now figure out how to make the side walls, but how about the roof with the holes that are perpendicular to the curve?
ā2009-07-22 10:50 AM
Sloan wrote:Use complex profiles for modeling as a wall, make a simple wallhole window that will punch a hole perpendicularly.Steve wrote:On this one, I think I can now figure out how to make the side walls, but how about the roof with the holes that are perpendicular to the curve?
ā2009-07-22 11:25 PM
Sloan wrote:You mentioned OBJECTiVE in an earlier post - I think it will help you a lot modelling this. I've attached a few example images to illustrate, but that's just the tip of the iceberg.
ā2009-07-24 12:36 AM
