Advice on teaching REVIT users ArchiCAD
Anyone have any advice on teaching REVIT users ArchiCAD? I've found that the sooner a new user starts focusing on using ArchiCAD as ArchiCAD and not trying to use it like a former drafting program, the better. This is much easier done when the previous program the user knew was AutoCAD. I find there's more resistance with REVIT. "Well in REVIT if I did this it'd work. Why can't this program function exactly like that?" I'm hoping that I can point out some things that happen in the early stages of modeling to help highlight the joys of working in ArchiCAD v11. So far some of the things I've mentioned haven't left this user that impressed...
Thoughts? Teaching techniques you've used?
Thanks.
Jared Banks, AIA
Shoegnome Architects
53 Replies 53
Erika Epstein
Matthew wrote:
Revit's strengths are evident early in the learning process whereas ArchiCAD's advantages show up on more advanced levels.
Matthew, what would you say Revit's strengths are? Conversely what would you say Archicad's strengths are?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Erika Epstein
Matthew wrote:
My own experience has been that Revit was very easy to get started with but as I pushed it further and harder it became progressively more difficult and frustrating.
Reading the article "How AutoCAD software is used to supplement BIM workflows."
http://aec.cadalyst.com/aec/Column%3A+1-2-3+Revit/BIM-and-AutoCAD-1-2-3-Revit-Tutorial/ArticleStanda...
it seems that Autodesk's solution is to have users buy 2 CAD softwares: Revit for the modeling and Autocad for 2D detailing and annotating. From Revit you export DWGs use in Autocad. Does this mean you cannot do detailing and annotating within Revit? Are you unable to take a project from concept through CD in Revit?
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Just off the top of my head...
Revit:
- Automatic relationships between elements. Quick modeling. Element editing facilitated.
- Auto-snap between related elements. Quick layout, arranging/rearranging elements.
- Direct parameter editing.
- Simple (though clumsy) interface.
- Consistency: Everything is made of Families. All views are model views.
- Graphical editing of parametric parts.
ArchiCAD:
- Limited relationships mean things stay where you put them
- Precise and facile control and editing in all views including 3D.
- Guidelines, snaps, locks, constraints, hotspots, pet palette and numeric entry are more nuanced.
- Info palette shows properties of selected element and allows direct editing without opening dialogs.
- Sophisticated and customizable (though complicated) interface.
- Scripted GDL parts provide many more functions and capabilities.
- The marquee tool.
That being said, all of these are more complex than can be represented in a single line. Each could be the subject of a short essay.
This is a tricky topic since we are really comparing two of the top BIM products available today, that being said...
I've used Revit professionally for about three years and only recently (4 months ago...) switched to Archicad and I can say without a doubt that Archicad is far more flexible than Revit at almost everything from the way objects represent on each story (linetypes, fills, etc) to the ease with which objects (slabs, roofs, walls) can be edited. Especially objects (families in Revit) like cabinets and windows. Try editing the mullions on a Revit window...and you can kill hours easily)
I also teach Revit at a university and know first hand how difficult it is to teach and for students to learn. (Although students generally don't seem to mind since they are just happy to be in 3D...two years ago the construction side of our dept was all 2d ...)
Revit is all in all a good BIM program and so is Archicad. I personally think that Archicad offers far greater design flexibility and options for documentation. It also plays better with others (MACs, third party plug ins, etc) than the Autodesk giant does. But that's also one of Autodesk's strengths is that they are so popular (at least in the US market).
I would agree with the statement that Archicad's strengths really show up at intermediate or advanced levels of proficiency whereas that is where Revit really falters. (I worry with my students that Revit's limitations really begin to effect their designs).
By the way, yes you can go from concept to CDs with Revit without ever touching Autocad for detailing.
I hope this helps.
I hope this helps.
That's one of the best (and frankly speaking, most unbiased) comparisons of Revit and ArchiCAD, or of learning Revit and ArchiCAD, that I've ever come across. Along with Mathew's up above as well, of course.
I especially agree with your assessment at the end regarding the perpetual need for 2D clean-up and patching in ArchiCAD versus the full 2D Docs-3D Model integration of Revit allowing one to go very fluently from modeling to straight documentation minus all the 2D doctoring and detailing. GS have a lot to do with regards to integrating the 2D aspects of AC with the 3D representation, as well as the general state of Detailing tools and library resources (that are integrated with the 3D-Model - it is after all, supposed to represent AND contain the same 2D information) to diminish this tendency.
On the other hand, as you pointed out, ArchiCAD's strengths ( which, IMO considerably outnumber Revit's) only begin to become more apparent and vivid as one becomes more proficient with the program rather casually using it. It has a lot of hidden goodies, tricks and helpful workflow features which could greatly be facilitated by better help documentation and tutorials by GS. Regardless of the fact that GS already does a far better job of documenting Help, tutorials and Learning support, than Revit does.
Laura Yanoviak
I'm not sure that was what he was saying... nevertheless, I do agree that this is an AC weakness -- the need for (sometimes excessive) 2D embellishment in Views generated from the model (specifically elevations).
Erika Epstein
From what I saw demonstrated once, Revit s/e also require some tarting up.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
From what I've heard (and this is all hearsay), in Revit you can assign an individual line of an element in elevation a view-specific Pen, which it will remember, even if the element is moved/edited. This would eliminate a HUGE amount of 2D embellishment (and editing once most everything is modified) in AC.
Erika Epstein
Yes, I saw that demonstrated and was very jealous. I wasn't sure how that would work if you had volumes overlapping and then would the 2d line show or will it only show where the volume is seen? Or could the line then be disassociated etc.....
anyway, it is great to have some competition!
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Laura Yanoviak
This wish is somewhat related.
