2019-12-04
01:39 PM
2023-05-09
04:18 PM
Rubia Torres
2019-12-05 03:03 AM
2019-12-05 08:58 PM
Barry wrote:Thanks Barry
You could use the 'Align Tool' > 'Special Align' option.
But personally I would just drag the wall from the point you want to touch the slab to that slab point.
This can be done in plan or 3D (or elevation) and you can constrain the direction with the shift key and/or guide lines.
Feel free to also turn of layers so other elements do not get in the way.
2019-12-05 09:04 PM
Barry wrote:What I really want to do is to offset the edge. I can do that in a floor plan by selecting two walls, but I cNt seem to be able to do it in a 3D view
2019-12-05 09:42 PM
2019-12-05 10:27 PM
petsagouris wrote:Thanks, this worked perfectly!!!
You should be given the option in the pet palette in 3D View by using the Reference Line of the object (blue in the image).
2019-12-05 10:34 PM
another Moderator
2019-12-05 10:41 PM
ejrolon wrote:Thanks a lot that exactly what I wanted. So I select the group I suspend it and then I stretch it
You need to read about "Suspend Groups" with that option you can edit the whole group using "stretch segment/offset edge" and they will all change but if they are grouped without using suspend then you will not get the option.
