We value your input!
Amorphous shape with a thickness
I've drawn a closed amorphous shape with a spline. I'd like to add a thickness to it so it's like a slab but with a free form shape. No idea whether I can do that. Can anyone help?
6 REPLIES 6
The magic wand tool with a slab should work.
Not sure how they work together but I'll have a play and see what transpires. Thanks
Works just like a bought one. Great!
Aces!
Irrelevant for quick sketchy preliminary, but dramatically important for later phases: be aware that the slab edges will not be splines but a series of circular arcs which because of the way the magic wand settings work are not even tangential (they don't work as a clean 'intent translation' of splines into arcs). So for serious stuff one needs to sit down, figure out and draft that geometry the way it should be.
Understood. Thank you.
