Another Line Type Question
Thanks for your input on my previous question on how to create a line type with text. I was able to create a new line type with flying colors. However, I noticed that if a start a new project, the line type is gone from the default list of line types.
My question is how to make a new line type part of the default list of line types.
Martin
AC 8.1R1/W2K
Sony R505
Jacek
You can simply copy and paste.
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
Link
The linetype you created was in the ~other~ project only.
Some possible ways of getting it into your new project:
Make a module of the line and merge it into the new project;
Cut/copy & paste it into the new project;
Drag & drop it (if enabled) between two open AC's (PC only!);
Use Attribute Manager to Append/Overwrite it.
Good luck.
Link.
