Any Help On This? Door Presentation On Plans
I have been working perfectly with ArchiCAD presentation Until Today I noticed This!. A Door (D1) Appears to have Both Symbolic and Projected Presentation At The Same Time... I Have Never Come across Such A Situation, My guess is that it has something to do with the wall, I guessed so, because if a create a new wall and i put the same door from favorites... it appears perfect (notice D2). I don't want to start over, because of two reason, 1.the walls have too many elements, that if i want to draw new wall i will spend much time. 2. Even if i do so, and even when everything seem to be in order, after i close and restart the project, the new door (D2) appears with the problem again! (D1)!
Any help?
0 Replies 0
