Any idea when ARCHICAD 23 will be released?
Does anyone have a date for the release of ARCHICAD 23? When I fired up ARCHICAD 22 the other day, I saw a message saying my protection key had been updated to ARCHICAD 23, so I am hoping that the release is around the corner. We have some new projects starting up soon and would like to test them out in 23. Has anyone heard any rumors of a release date?
10 Replies 10
Steve Jepson
https://www.applecoredesigns.co.uk/
They expect it in the UK on the 23rd of September. Don't know if that will be before or after it is available in other areas. ??
Lingwisyer
Guru
See this post. It was apparently announced at the launch event.
Ling.
The INT version usually comes out first, closely followed by other English language versions.
Each country likes to add their own tweaks to their template so that is why these take a little longer after the INT version.
Then other languages follow soon after (at least I hope so).
So if the UKI version is set to be released on 23rd September and the AUS is on 8th October, I think it is safe to assume other English language versions will be out around the same time with INT on or just before the 23rd.
The USA gets everything first, so it will be released alongside the International version.
Eduardo Rolon
For some reason links are active now, so if your key is upgraded then you cann use it.
https://www.graphisoft.com/downloads/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Steve Jepson
ejrolon wrote:
For some reason, links are active now, so if your key is upgraded then you can use it.
Thanks! It downloaded and installed just fine.
Is there a Bimcloud 23 client available? Cant open my teamworkprojects with AC23
Noemi Balogh
Hi eschefer,
BIMcloud 2019.3 already supports ARCHICAD 23. You can download it from here: https://www.graphisoft.com/downloads/bimcloud/
BIMcloud Basic supports only one version of ARCHICAD at the same time, so in case you wish to use BIMcloud Basic with ARCHICAD 23, you need to install a new instance.
Kind regards,
Noémi Balogh
Staff Community Expert, Admin
nbalogh wrote:
Hi eschefer,
Kind regards,
yeees, works fine
thank you madam!
